Random one I thought you guys might have some advice with, I've been having a problem where every time I turn on my computer the tv signal craps out in the house over certain frequencies, it goes away when I turn it off.
I narrowed it down to the power supply by unplugging everything and turning it with a paperclip and nothing attached. Problem wasn't as bad but still there. Plugged in everything without graphics card, worse, then with GPU worse again.
Does the same thing on other power rings in the house and ferrous rings don't make much difference. I plugged in a no brand pos 500w psu and it didn't cause any problems at all (but has no 6 pin plugs)
Anybody got an idea for how I might try a homebrew 'fix' as I don't have the receipt and brought it back in the UK (live in Australia now, same power standards btw) so it's a fix it or bin it type thing. A 1KW Seasonic is going to be $300 here so hence I'd rather try and sort it.
Anyway if anyone knows what I can try to fix it it'd be appreciated.
