Elon Musk's Flamethrower Tested
Discussion in 'HardForum Tech News' started by AlphaAtlas, Sep 18, 2018.
  1. AlphaAtlas
    AlphaAtlas [H]ard|Gawd Staff Member
    1,713
    Mar 3, 2018
    DriveTanks.com pitted the Boring Company's "Not a Flamethrower" flamethrower against a commercial XM34 and a US military M9 flamethrower. As it turns out, "Not a Flamethrower" is a pretty accurate name.
    See for yourself in the video here.
  2. Jagger100
    Jagger100 [H]ardness Supreme
    7,420
    Oct 31, 2004
  3. TheOne&OnlyZeke
    TheOne&OnlyZeke 100% Irish
    10,192
    Jul 21, 2000
  4. modi123
    modi123 [H]ardness Supreme
    5,143
    Sep 6, 2006
    Did anyone expect Musk's flame-toy to be remotely close to a military grade flame thrower?
    Eshelmen, katanaD, AceGoober and 6 others like this.
  5. [21CW]killerofall
    [21CW]killerofall Aliens...
    2,791
    Mar 16, 2006
  6. cyclone3d
    cyclone3d [H]ardForum Junkie
    12,893
    Aug 16, 2004
    So all you really have to do to make it a flamethrower would be to add an attachment that shoots out a strong stream of diesel or alcohol, or whatever.
    All the "Not A Flamethrower" is is a propane torch.
    A can of WD-40 with the straw on it makes a better flamethrower then the Not A Flamethrower.
    AceGoober and DrBorg like this.
  7. iamjanco
    iamjanco Limp Gawd
    439
    Jul 8, 2016
    Meh, we already knew about Musk's culvert clearer. My attention was drawn more toward the tanks in the rear.
    Can you get disabled plates for those in TX?
    Jim Kim likes this.
  8. Mut1ny
    Mut1ny [H]ard|Gawd
    1,854
    Apr 4, 2013
    He said int he JRE podcast that it's literally a roofers torch with a shell on the outside. So, no, it isn't a flamethrower. Still cool to own just for the lols though.
    Edit: Also, watched the video, can't stand Texans. "Well Elon that's how we do it here in Texas"...no you redneck mother fucker, it's how the United States military created the M2 flame thrower 70 years ago.
    Sorry, having lived in Texas I just got irritated by the whole "Texas does it best" on everything even though they, ya know, didn't...go visit Lubbock and tell me that shit..
    btgorman, AceGoober, Trimlock and 4 others like this.
  9. kilroy67
    kilroy67 Gawd
    648
    Oct 16, 2006
    There is a reason why the WW2 flamethrower operator was a prime targets for the Japanese defenders. Japanese soldiers after the war feared the M2 flamethrower more then any other weapon the Americans possessed.
    AceGoober likes this.
  10. steakman1971
    steakman1971 2[H]4U
    2,433
    Nov 22, 2005
    Not surprised. When I was a teenager, a buddy of mine built a scaled down "flame thrower" (more range than Elon's, but not even close to the WW2 model). From my memory, he used a fuel mix of diesel and some type of oil. It smelled pretty bad, burned black smoke - guessing the range was about 10 feet or so? (His parent's found out he built it and confiscated it)
    His dad had a workshop - this guy used to build all kinds of stuff. He built pipe bombs out of black powder (can you imagine nowadays? He also blew up a dog house (dog was not in it). Again, parents took these away...)
    I lost track of this guy. Wonder what he ended up doing... I wouldn't have been surprised if he turned up on a TLC show or something someday making stuff. He wasn't a violent or crazy person - just an industrious teenager with access to stuff. If there was ever a zombie outbreak, you wanted this guy on your side.
  11. NWRMidnight
    NWRMidnight Limp Gawd
    207
    Oct 23, 2010
    You don't even want to attempt this. I was using wd-40 to oil a dryer bearing (was going to just replace it, but my brother just told me to oil it with WD-40- it was his dryer). So, 3 hours after my sister in-law used it, I checked to make sure it was cool, and everywhere I could get to was cool, but way back in the back, in the corner it was still hot I found out. Anyhow, I went and started to oil the bearing, and it ignited, shot up the stream causing the can to exploded/shoot flames out the side about 2 inches from the bottom (which I am guess is designed to do so it doesn't just explode completely , singed my eyebrows and goatee, cough the box and blanket behind me on fire, as well as singed my pour dogs coat in his side. (he wouldn't come near me for the rest of the day... I don't blame him.. LOL )
    Anyhow, I know you used it as just an example, but, be warned, it will not work out so well, so don't ever try it, even if you have been successful before.
  12. cyclone3d
    12,893
    Aug 16, 2004
    Were you using the straw?
    I actually did this multiple times when I was a teenager. Have to stop using it once the tip of the straw starts to melt from the heat.
    The only way I can see it going all the way back to the can is one of these:
    1. No straw
    2. Stream is not shooting fast enough to keep the flame from traveling back to the can.. Maybe didn't shake the can before use or the can is almost out of propellant.
    AceGoober and IdiotInCharge like this.
  13. Jim Kim
    Jim Kim 2[H]4U
    3,307
    May 24, 2012
    Someone is telling a TALL tale or forgot the Poes Law /s tag.
    In order for a fuel to ignite it needs to combine with (usually) oxygen. There is no oxygen in the can so the flame cannot backup into the can to explode.
    This is the same reason a gas stove does not send the flame back down the pipes. And we all know about those exploding propane tanks on bbq grills.;)
  14. modi123
    5,143
    Sep 6, 2006
    Yeah.. some cat made a similar blow torch while the 'not-a-flamethrower' thing was being made.
    Seems fairly similar. So I can only imagine some enterprising [H]-goon cranking these out for christmas.
    Side note - the terms of service was a nice touch.
  15. cyclone3d
    12,893
    Aug 16, 2004
    True. If the can has a leaking sprayer, I can see the WD40 on the can catching fire and in turn melting the plastic valve which would end up causing a nice shower of flames and possibly an exploding can.
    If the straw wasn't being used I can also see the flame going all the way back to the spray nozzle as when using the straw, the flame goes almost all the way back to the straw and starts melting it.
    Too many questions for said story teller who has not replied back yet.
  16. Exavior
    Exavior [H]ardForum Junkie
    9,646
    Dec 13, 2005
    mine explode all the time. just last night i was sneaking about some back yards, the cops shot at me and boom random propane tank next to me exploded. After i woke up in the parking lot if the hospital with half my money gone i decided to be more careful around them. I have lot millions of dollars because of them.
    DrBorg, cyclone3d and Jim Kim like this.
  17. Mut1ny
    Mut1ny [H]ard|Gawd
    1,854
    Apr 4, 2013
    Legitness.
  18. oldmanbal
    oldmanbal [H]ard|Gawd
    2,037
    Aug 27, 2010
    one is a stock roofing torch, hence why it's called not a flamethrower, and the other is a flame thrower. Lets compare intel cpus to nvidia gpus next!
  19. NoOther
    NoOther [H]ardness Supreme
    6,413
    May 14, 2008
    While this is true, I have exploded many a can back in my younger years. You just need a second source, a hole punctured in the can followed by lighting it can create this fun experience. Or simply tossing a can in the fire, letting it melt a hole and then watch it explode.
  20. DrBorg
    DrBorg Gawd
    555
    Jan 22, 2005
    The best flame I ever got out of a can was by shooting a can of Lysol in a brushfire. Nice!
  21. Mike89
    Mike89 Gawd
    702
    Jan 27, 2003
    Lol, it would be cool as hell to have the Elon Musk one to light my barbecue. Would be a nice conversation piece.
    pendragon1 likes this.
  22. Zepher
    Zepher [H]ipster Replacement
    16,663
    Sep 29, 2001
    That is pretty neat.
    But WTF, do these people not watch what they edit before posting? The friggin audio levels are all over the place, I couldn't hear the dude on the right during the closing of the video.
    One thing I hate doing is playing with my volume controls when watching a video.
  23. Susquehannock
    Susquehannock 2[H]4U
    3,196
    Jul 26, 2005
    Not a flamethrower is really a torch. No surprise there.
    WD-40 was/is developed as a water displacement product. It is mostly kerosene and a piss poor lubricant. Those who use it as such get what they deserve.
  24. mynamehere
    mynamehere [H]ard|Gawd
    1,764
    Jun 30, 2007
    What a disappointment. I was hoping for something that would at least clear my sidewalk this winter. Looks like at the very least I need an XM42, but with the XL18 I could be a hero and clear the neighbor's walk at the same time. Decisions, decisions.
  25. Verge
    Verge [H]ardness Supreme
    6,113
    May 27, 2001
    Tex-Mex
    BOOOOOOM!!!!!
  26. Mut1ny
    Mut1ny [H]ard|Gawd
    1,854
    Apr 4, 2013
    FLAWLESS VICTORY!
    vividshock and AceGoober like this.
  27. Methos
    Methos Limp Gawd
    325
    Jul 21, 2004
    THATS HOW THEY DO IT IN TEXAS!
    I think these kind of videos were to be expected. Imagine the Amazon reviews.
    1 Star
    Followed instructions exactly, but while attempting to burn my Vietnamese neighbors out of their home, police arrived and confinscated my ‘not a flamethrower’. Will be looking for a re-homed M9 for any future attempts at arson.
    Edit: and it’s all Elon Musks fault.
    -Anomie- likes this.
  28. hexamon
    hexamon [H]Lite
    98
    Oct 21, 2006
    In the Joe Rogan interview he did he said this movie was what inspired him to sell a flamethrower. He liked the idea of the company gift-shop always being stocked with one absurd item at at time.
  29. focbde
    focbde Gawd
    546
    Jan 31, 2008
    Know what you mean... I love Texas personally but it can get a bit annoying eventually. Plus, I wonder how many anti-Hillary posters/stickers/shirts/etc. they have hanging around that place :D
  30. knowom
    knowom Limp Gawd
    419
    Aug 15, 2008
    Could make as good flame thrower w/a bit of ether starter fluid that's not nearly as boring.
  31. painintheworld
    painintheworld [H]Lite
    116
    Jun 5, 2007
    We used to do similar stuff whilst camping at the local lake in the 1980s. We’d round up a bunch of mostly empty spray paint cans, a bunch of beer and/or moonshine (often mixed with shrooms or LSD), build a bonfire and toss the cans in the fire. It is quite amazing that A: we lived through those years and B: how high those damned cans would go in the air. Wild teenaged boys and girls.
  32. Dan UCF
    Dan UCF [H]ard|Gawd
    1,082
    Aug 3, 2003
    Did anyone else see the hottest (mirrored) Adidas logo when they lined up to show the varying distances each could "throw" fire?
  33. Hatriot
    Hatriot Limp Gawd
    144
    Jan 18, 2018
    Yes most beta nerds are generally angry at men doing men stuff. Think you can find a guy in San Francisco would even be able to pick up one of those much less know how to use it? Think there is a place in Vermont where I can go fire an actual tank? I know it hurts your progressive feelings, but sorry this guy has earned the right to talk smack. Yes they probably didn't vote for gangster Hillary, but there are plenty of other types that did.
  34. Mut1ny
    Mut1ny [H]ard|Gawd
    1,854
    Apr 4, 2013
    Someone has some self esteem issues lol..
    oROEchimaru likes this.
  35. Neutrino
    Neutrino Gawd
    602
    Nov 10, 2005
    So they discovered that a product called "Not a flamethrower" is not actually a flamethrower ... guess on the next episode we'll find out if you get wet when when swimming in the ocean (y)
    e-thugging in progress ... :ROFLMAO:
  36. oROEchimaru
    oROEchimaru [H]ardness Supreme
    4,658
    Jun 1, 2004
    ** loads up team fortress 2 **
  37. oROEchimaru
    4,658
    Jun 1, 2004
    beta nerds? wtf man
  38. modi123
    5,143
    Sep 6, 2006
    What peasant would have it uninstalled?! Ha!
    TF2 > Fortnite.
  39. oROEchimaru
    4,658
    Jun 1, 2004
    i loved tf2 it was great... after it went free for play i never could find a server that wasnt full of hackers... it became no longer fun to play when you cant counter auto aim and auto snipe. maybe its better now. wish they would make an xbox one version
  40. Nebell
    Nebell [H]ard|Gawd
    1,543
    Jul 20, 2015
    What are these, some american rednecks?
