I have ugrid = 9 for the last week (15+ hours of play) and have gotten not one crash (until the new patch f*** that up, but I just went back to the old .exe to fix it), all I did was enable LAA and add the following to documents\my games\skyrim\skyrim.ini under papyrus:
I can't understand how LAA and the above ini settings really help because I've never seen tesv.exe use more than 1.4GBs of RAM, you'd think it'd run fine without LAA but I was getting constant crashes before applying LAA..go figure. Ah just remembered, windows task manager does not always report every bit of memory used because of intrinsic difficulties in doing so.
Code:
[Papyrus]
iMinMemoryPageSize=100000
iMaxMemoryPageSize=5000000
iMaxAllocatedMemoryBytes=3200000000
