According to EKs compatibility list the waterblock should be compatible with my MSI Z97 MPower MAX AC motherboard. But when I went to install it the backplate gasket overlaps with several wire protrusions from the front of the board causing it to lift up on one side instead of laying flat. Can I trim the gasket around where it's conflicting with my board so that it will sit flush on the board?
