EK Asus X99 Monoblock, EK XTX 360 64mm thick Radiator, Caselabs SM8 Case, Asus x99-a II 5820k Combo
Cozmo85
EDIT: radiator sold elsewhere
EDIT: 2 monoblock sold
Selling an EK Asus X99 Monoblock
Monoblock comes in original packaging with original accessories and used thermal pad. Should work fine but may want to order a replacement pad on ebay. Supports most of the Asus X99 motherboards as you can see here https://www.ekwb.com/configurator/waterblock/3831109821459
This is a nickel/plexi block and has never been taken apart. Flushed with distilled water. The orange you see in the photos is the oil EK uses on their o rings and is normal.
Asking $100 shipped USPS 1-3 day priority
https://i.imgur.com/wtQ35Bxh.jpg
Selling a Caselabs Merlin SM8 case.
Configuration is below. Cost from caselabs is $610 before shipping. Shipping would be $30-$100 from caselabs depending on location.
https://i.imgur.com/3oj2289.png
The case is all aluminum with a large side window which is in pretty good shape. Has some scratches which are typical of plexiglass. Plexi is easily removable if you ever wanted to replace it.
Case has 480 radiator mount in top, 360 radiator mount on top, and 480 radiator mount on bottom. Keep in mind PSU does block parts of the top or bottom radiator mount (obviously depends on if you mount the psu on top or bottom. Also has front panel audio and 4 usb 3 ports.
There are 4 holes drilled in case for a d5 EK pump mount. You can see them as a rectangle pattern in the lower left corner of the inside of the case. They are hard to see with the back of the case on plus the exposed metal has been colored black.
Case can be rebuilt so motherboard is on either side of case. Original instruction manual included.
Includes the case, parts and accessories, and documentation.
Ignore the discoloration in the photos, its due to the overhead lights at my work. The case has a smooth black finish. Case is currently built in an inverted layout.
$400 shipped to 48 states ups/fedex ground
https://imgur.com/a/7nLlS
MB + CPU sold
Selling a 5820k CPU and motherboard together.
Motherboard is an Asus x99-A II
https://www.asus.com/us/Motherboards/X99-A-II/
Works fine and is perfectly stable however the asmedia 3.1 ports do not work which is a common issue on this generation of asus boards. This means the usb type C and port above it do not work on the back. Other ports all work fine.
EDIT: to clear up which port has issues its the Type C and the teal type A above it.
https://images10.newegg.com/BizIntell/item/13/132/13-132-830/32_052416.jpg
Includes cpu, motherboard, motherboard box/packaging/documentation/accessories.
CPU socket has no bent pins.
CPU Is an Intel 6 core i7-5820k.
Asking $350 shipped for the combo usps priority 1-3 day.
https://i.imgur.com/gMTdbgbh.jpg
https://i.imgur.com/VIjjFk9h.jpg
https://i.imgur.com/VBiXgooh.jpg
https://i.imgur.com/D06x9wWh.jpg
