Archaea
- Oct 19, 2004
Which will be the most efficient power supply configuration on two Asic Antminer Z9 mini (stock each is rated at 300 watts - overclocked 70% is 400-450 watts)
A) Raidmax 1000 watt Vampire (Gold Rated) - One PSU powering two Z9 Minis.
B) (2) Raidmax 1000 watt Vampires (Gold Rated) - One Z9 mini per power supply.
C) (2) EVGA G3 850 watt (Gold Rated) - One Z9 mini per power supply.
I have two z9 mini's and 4 power supplies to test. None of the power supplies are over 1 year old. The load will be constant and identical for each test. In each test I let the units run at least one hour to get up to temperature and at the time I took the pictures/reading - the reading was static (within about +-1 watt). The ASICS were mining Equihash - which is the same algorithm and should be the same computational power thus power draw. Overclock settings identical. These tests were all done the same day in my 72* air conditioned basement - so heat should not be a factor.
I'll tell you I was dead wrong on my guess before I tested.
Answer!
Answer!
C is most efficient by nearly 50 watts
A) Raidmax 1000 watt Vampire (Gold Rated) - One PSU powering two Z9 Minis. = 870 watts
I figured this single power supply would be the most efficient, because I reasoned that you'd lose more electricity in running two power supplies than you'd gain in an efficiency curve mapping.
B) (2) Raidmax 1000 watt Vampires (Gold Rated) - One Z9 mini per power supply. = 855 watts
C) (2) EVGA G3 850 watt (Gold Rated) - One Z9 mini per power supply. = 805 watts.
I did not try one 850 watt EVGA to the two miners because the single Raidmax 1000 watt read ~870 watts with the two units and I didn't want to potentially exceed the EVGA's power supply max threshold for an hour to complete the apples to apples test.
