Edifier 2.1 -> Dorm room 2.0 - Help!
Discussion in 'Computer Audio' started by ValeX, Mar 29, 2012.
  1. ValeX
    ValeX 2[H]4U
    2,176
    Dec 23, 2005
    I currently use the 2.1 Edifier S730's with my PC/PS3/360 at home. http://www.edifier.ca/products/edifier-multimedia/s730.html With this sound card: http://us.store.creative.com/Sound-Blaster-XFi-XtremeGamer/M/B000J1F1BI.htm I use Sennheiser PXC 350 headphones.
    I am moving to a dorm room in a month and bringing my computer with me. I don't want to bring the subwoofer as it will just be a nuisance. I want to downgrade my setup to a 2.0. Should I buy a receiver/amp that can take audio inputs from my PC/PS3/360 and play out the Edifier bookshelf speakers I already own? I have zero experience using receivers and am looking for advice on what I should buy to hook my speakers up and leave the subwoofer at home.
    Desired receiver inputs: RCA, aux-in, optical
    Desired receiver outputs: Red and black speaker wire, headphone
    Should I just get a mini one like one of these?
    http://www.amazon.com/Lepai-Tripath-Class-T-Amplifier-Supply/dp/B0049P6OTI/ref=cm_cmu_pg__header
    http://www.amazon.com/PCA2-80-Watt-Stereo-Power-Amplifier/dp/B001P2VV50/ref=pd_cp_e_0
    http://www.amazon.com/Dayton-DTA-10...ef=sr_1_3?s=aht&ie=UTF8&qid=1333005892&sr=1-3
    What are my options?
    Budget $100?
    Thanks for any input!
  2. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    Buy the tripath amp and a cheap headphone amp someone will list one.
    Also can I buy your sub for price of shipping plus a little if you want?
    Also worth noting that the dayton is fairly good, Just there are better options.
    Another thing is that you will lose a bit of bass, Anything <80hz
    http://www.youtube.com/watch?v=EL4QHH5Hhdg&feature=related
    Not to bad.
  3. bAMtan2
    bAMtan2 [H]ard|Gawd
    1,454
    Sep 16, 2008
    just don't spend much money on this.
    dorm speakers are a funny thing. the only reason for dorm speakers is to learn you don't need dorm speakers
  4. ValeX
    ValeX 2[H]4U
    2,176
    Dec 23, 2005
    I guess I should mention I use these headphones as well: Sennheiser PXC 350
    So I need a tripath amp which connects my sound card to my satellite speakers, and then I'll need a headphone amp to connect my headphones to the triamp? Is that correct? Maybe I should just get a headphone amp and leave my edifiers at home altogether?
    (Ps - manny - I've decided I'll keep my subwoofer at home until I return so I can use it again.)
  5. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    Just go ahead and grab the dayton amp. Itll be fine i guess its worth the ability to have a all in one.
    Its good, That is worth keeping, That is a very clear sub.
  6. 450
    450 Pick your own.....you deserve it.
    21,271
    Feb 19, 2007
  7. ValeX
    ValeX 2[H]4U
    2,176
    Dec 23, 2005
  8. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    I guess those could be good, Something seems amis to me on them possibly the specs listing it goes down to 20hz, I dont think 20hz is a usable output on them. That and the tweeter looks fake.
    When you get them post some pics and impressions please?
  9. 0055
    0055 Limp Gawd
    415
    Aug 27, 2010
    The whole point of dorm speakers is to annoy the shit out of everyone else, bring the sub!!!!!
    The real reason why subs are annoying is because of bass humps due to the tuning of their design (passive radiators and ports result in box tuning), if the company tunes it on purpose to have a bass hump then even at low volumes your sub might play 40-50hz at TWICE (+6db) the volume of everything else. I like to think edifier does not do this. Logitech are infamous for doing this shit and as a result are the worst fucking company on the planet (my roommate had logitech speakers and seriously fuck logitech)
  10. lilfiend
    lilfiend [H]ardness Supreme
    6,496
    Nov 28, 2008
    i've got a pyle amp and it drives two sony bookshelf speakers just fine, plus its rms power is pretty good, and it has a built in ac/dc adapter.
  11. ValeX
    ValeX 2[H]4U
    2,176
    Dec 23, 2005
  12. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
  13. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    Grab the dayton for the headphone amp.
  14. pharoah
    pharoah Limp Gawd
    195
    Mar 10, 2008
    100$ budget +1 on the dayton amp.
  15. ValeX
    ValeX 2[H]4U
    2,176
    Dec 23, 2005
    I have taken all of your suggestions into consideration and decided on the following:
    Since I imagine I won't need speakers all that much in a dorm room, and I happen to already own a bose sounddock portable http://www.bose.ca/controller?event=DTC_LINKS_TARGET_EVENT&DTCLinkID=7792&dssourceid=k1638&src=k1638 which I planned on bringing anyways, i will simply hook my sound cards audio out straight into that thing. I can bring it outside and stuff too when I'm not using my computer. I will use headphones plugged into a long extension 3.5mm cord from the sound card as well. It's basically like buying a speaker set with a built in amp except I already own it :cool:
    And im leaving the PS3/Xbox360 at home.
    Thanks for all the suggestions.
  16. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    Lol gross... :D Well it was the cheapest option.
  17. fss69
    fss69 Gawd
    638
    Nov 30, 2007
    How dare you use logic when making a purchasing decision! :)
  18. anthrex
    anthrex [H]ard|Gawd
    1,870
    Jul 7, 2004
    Best decision don't be that guy. Enjoy college!
    PS Also college girls don't know the difference between good and poor quality audio. You'll be fine :p
