I currently have an E8400 @ 3.6Ghz, DFI LP DK P35-T2RS, G.Skill 2x2GB DDR2 1000, MSI NX8800GTS G92, and some anciently slow WD & Samsung 250GB SATA HDDs that I'm currently running in RAID0 (HD Tune tested the RAID at about 111 MB/s transfer rate, about the rate of both individual drives combined, and 13 ms access time).
I've been planning out basically a system wide upgrade (CPU, RAM, motherboard, video card, power supply, and possibly hard drive) since it's been about three years since my last component was put in my machine and I've been researching very thoroughly and diligently as of recently. I'm a graduate student with a limited stipend and savings so I'm trying to come up with a monetarily efficient build.
I'll mainly be playing a couple games, namely TF2 and WoW but I would also like to be able to experience the newest and latest games in their full glory, such as Metro 2033.
I already bought the first two components, being an i7 930 from Micro Center for $199+tax and a Corsair 750TX for $80 AR from Newegg. As for the motherboard, RAM, and video card I'm looking at a mid to high end X58 board, 3x2GB DDR3 1600, and one or two GTX 460 1GB cards once the prices drop some more.
For my current system, I was unlucky enough to get a sluggish E8400 that can't go much higher than 3.6Ghz without giving errors even though the temps are well under 60C at full load. I've even tried as much as 1.47 Vcore and it will still toss me an error after a while even at 3.8Ghz and the temps are fine. Anyway, I always wanted to hit over 4Ghz stable and that's why I chose the i7 930. From what I hear it can hit over 4Ghz on a good motherboard with ease and if I'm lucky with the chip I got I may be able to push even higher.
This brings me to the rest of my components. What I was thinking for now is as follows:
1. Asus Rampage III Formula
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131666
2. Corsair Dominator 3x2GB DDR3 1600
http://www.newegg.com/Product/Produ...corsair_dominator_ddr3-_-20-145-224-_-Product
3. Corsair Hydro H70
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181013&Tpk=h70
And later down the road I was thinking of getting 1-2 GTX 460 1GB cards to possibly run in SLI. To me I've been eying the Asus ENGTX460 DirectCU TOP card in particular. Also, I could probably add a nice SSD drive or maybe just get a newer higher capacity SATA drive or two and raid them.
My questions for the community are as follows:
Does what I have now look good? I'd like to spend no more than ~$1000 in total on remaining components and no more than ~$600-700 right now for the motherboard, RAM, and cooler.
Is there a better motherboard choice? Would the Rampage III Extreme be a better board for higher overclocks? What about the EVGA E760 Classified or another board? My concern is that if my 930 is from a bad batch or that my overclock is vastly limited by my chip, spending all that extra money on a quality motherboard would potentially be a waste.
Is there a better RAM choice? Is it worth it to save some money here or spend more and go with a different brand or speed?
Would an SLI configuration really help? I'm on a Samsung 193P+ 19" LCD (1280x1024).
Would saving money on these components and getting a nice custom water cooling loop be worth it for a higher overclock? If I don't end up getting an amazing 930, would I rather be limited by my chip itself with the H70 before temperatures become an issue and give rise to instability, in which case all that money on the custom water cooling would potentially be wasted?
