Astral Abyss
- Jun 15, 2004
I've got the system listed in my sig running my new E8400. I replaced a Q6600 G0 that ran at 3.2GHz hoping for much higher clock speeds since most of my time is spent playing games that only utilize 2 cores max.
The E8400 is currently running at 3.8GHz (9x423) on my Abit IP35 Pro. Cooled by Thermalright Ultima90 w/120mm Scythe S-Flex (1200rpm)
CPU @ 1.3975v in BIOS. 1.38-1.39 idle / 1.36-1.37v load in CPU-Z.
CPU VTT @ 1.1v
MCH @ 1.44v
ICH @ 1.17v
ICHIO @ 1.65v
CPU GTLREF 0&2 = 63%
CPU GTLREF 1&4 = 63%
(EIST and C1E are disabled)
RealTemp reports 36-38C idle, 58C load (both cores are the same temp), uncalibrated.
- raising the VTT has so far only resulted in BSOD during boot
- I had to raise the ICH/ICHIO to stop iastor from crashing with a BSOD during disc access(running AHCI mode in XP)
- MCH voltage boost allowed me to lower the CPU voltage 1 notch.
- GTLREF I've just been playing with to see if it would make any difference. Negligable so far.
So, what do you guys think? It's a Q808 batch. Should I just be happy with it? Seems like it needs a lot of volts just to get it 3.8GHz stable. I was really hoping to push it to 4+GHz. I don't want to kill the chip with too many volts until more info is available on how much damage it does to these little 45nm dudes, but I'm also not worried if the chip dies after 2 years since it'll be old news to me by then.
Any opinions or suggestions?
CPU VTT @ 1.1v
MCH @ 1.44v
ICH @ 1.17v
ICHIO @ 1.65v
