Specs: IP35 Pro, DDR 800 RAM, Seasonic M12 600 power supply
I used to run my E6600 at 3.6 GHz (9x400), indicating to me that my board didn't have a problem at 400 MHz FSB.
When I got my Q6600, I first tried a small overclock. I upped all voltages a little (to make sure I could boot) and set it at 7x400 for 2.8 GHz. It boots fine, temps were OK, but it would crash going into Windows or within a few minutes of being in Windows. I then tried moving voltages back to stock, just in case the extra heat was overwhelming the TRUE 120. Once again, no dice. At that point I said screw it and was running at stock multiplier and FSB for about the last 8 months.
Recently I've been wanting an overclock, so when Fry's had their sale on the Q9450, I bought one and was configuring a new build in my head. Before I spend all that money, though, I figured I'd give the Q6600 one last shot, which I did last night.
Once again, 7x400 @ 2.8 GHz was a no-go. I don't know why I didn't think of this before, but I then thought about setting it at stock CPU but higher FSB. So I went 6x400 MHz at stock voltages and this didn't work either. What could be causing this? Is there a voltage I can increase to fix this?
Then, for poops and giggles, I set the FSB at 333 and multiplier at 9 for 3 GHZ. I kept all voltages and stock, and what do you know? Gets into Windows fine and I gamed for 3 hours without a problem.
What should I do? I'd like to get my RAM running 1:1 as high as possible, so 400 MHz FSB would be great. How do I get there though?
Cliffs:
1) E6600 worked at 3.6 GHz = 9x400
2) Q6600 WON'T work even at stock CPU speed 2.4 GHZ = 6x400
3) Q6600 WILL work at 9x333 = 3 GHz with no increase in any voltage
4) What is the problem here, and how can I get my 400 FSB back?
Cliffs:
