- Aug 12, 2004
So I'm downgrading/upgrading to the slightly slower but more cores 2667's.
For active DC members I'll sell these two extra spicy E5-2643V3 cpu's for $100 each.
There is a potential/possible issue though. Since the microcode updates, and I'm not sure if it its the Windows 10 patches or this Dell T7910 BIOS ones I have had occasional crashes. Seemingly at random but definitely more when I have the system heavily loaded. Never really know though. System might be up for 3 weeks without a single problem or it might be up for 3 days.
Since this is a machine I rely on to make a living I've bit the bullet and ordered two 2667 V3 cpu's to replace these ES ones in hopes that I can end the random crashes. The other day I lost a half a day of work and I cannot risk that instability. I got these in November of 2016 and really have had zero issues until around when the spectre stuff came about. So I'm personally attributing the crashes to that. I've run 24+ hour ram tests and everything else and cannot find any other reason for crashes. Cannot remember where but I did read something on some site that indicated that this is likely the reason for crashes on the early stepping V3 cpu's. I'm not going to try and roll back the various Windows patches and try to downgrade the BIOS on this machine though.
I believe these are the earliest QEYM stepping which is probably why I've had crashes. That being said, if you run them on an older board without all the microcode updates for spectre crap and some of the Windows patch updates for the same they will probably run just fine.
On the plus side I'll soon be helping out on the challenges again with even more cores.
If one of you wants to test first before buying I'll also work with you on that and if they are unstable for you then I'll take them back and eBay them.
Once the others I'm replacing these with come in I'll post a pic of the actual CPU's. That will probably be late next week. For now a CPU ID and Intel IPDT screen shots. On IPDT, if you are not aware, brand string and SPBC are expected fails on ES and QS CPU's... SPBC is actually a check if the CPU is an ES or QS and the brand string is not encoded on ES and QS CPU's.
