Hi Everyone
I've been trying the E4300 pin mod with the ECS motheboard that came bundled together at Fry's the other day.
I did the mod correctly and I was able to boot up at 266mhz FSB resulting in a CPU speed of 2.4ghz. Next step I went to push the FSB to 300mhz (as allowed by the ECS motherboard).
It doesn't boot up. The power supply comes on but I get no video.
Look at the pictures here:http://www.ocforums.com/showthread.php?t=498167&page=2
That guy was able to hit 300mhz easily on the same ECS motherboard after modding his E4300 to run at 266mhz.
I've tried and 284mhz is my maximum that I can get. This is a (284/266) = only 6% overclock of PCI/AGP bus.
I know that a 13% overclock of PCI/AGP bus is allowable since before I did the mod I was able to get my FSB up to 226mhz. Thats (226/200) = 13% overclock of PCI/AGP bus.
So why do I get a blank screen when I try to run my PCI/AGP at higher than 6% out of spec with a CPU FSB of 266mhz when I was able to run my PCI/AGP at 13% out of spec with a CPU FSB of 200mhz?
Anything else I could be doing wrong?
