Hi guys,
Due to some recent good fortune i've got some spare cash lying around for me to do an update to Core2Duo. I am on a budget and as such have decided to go e4300, 1GB DDR2 800 (cheap stuff for a while till I can afford the 2GB OCZ XTC Rev 2 DDR2-800) and either a DS3 or AB9 Pro.
Really I after a mid range board with some decent features but also able to maintain a decent OC (3 to 3.2GHz would be a great goal). I will be using my Big Typhoon from my current 939 setup.
Reason I have picked those boards is that:
a) I don't do Asus boards as the BIOSs drive me crazy and have had plenty of bad experiences.
b) I don't need SLI or Crossfire
c) 6 + SATA ports is very useful.
d) Gigabyte is £78 and the Abit is £90.
So which would you go for out of those two boards or any other suggestions than Asus.
Cheers
Cheers
