Just setup a esd earth point which runs straight out to a earth stake. Is there someway I cant test it to make sure it works properly?
One way is to grab a DMM or similar and compare the potential between your earth point and an outlet, assuming it works the same as here in Europe (one DMM lead in outlet, other on earth point, should be 240VAC here, ~120VAC in other places). If it's significantly lower, there's some resistance along your path to ground and thus unsuitable as-is.
If it's significantly higher, you may have other issues
You are precisely correct. The point of the anti-static wrist strap is two fold: to keep you grounded (and thus prevent static build-up in the first place), and to ensure that any built-up charge is dissipated nice and gradually.I know the words here may not have been perfect but I believe it should give you the right idea. You may want to ensure your ESD wrist band actually has a safety feature that gives it a high resistance to your ground strap (I think it is even a megaohm.. but I'm not sure). Also I believe a high resistance on your wrist strap or mat will slowly dissipate the charge rather then a quick spark which could damage electronics more easily. At work we sometimes can demonstrate this... we can build up static and see a spark if we carefully touch the edge of the mat near the bottom side with a fingernail rather than the top of the mat. I believe this is because the bottom of the mat is actually much more conductive while the top of the mat is resistive.
