Nov 16, 2004 #1 S spin02 Limp Gawd Joined Aug 13, 2004 Messages 196 I have a 40" Sony Wega (CRT) with DVI inputs. When I connect my X800XT-PE to it I get signal until windows starts to boot. Then I goes dead. Any thoughts?
Nov 16, 2004 #2 C Canon 2[H]4U Joined Aug 12, 2004 Messages 2,614 Try going into your display properties->displays tab->turning on TV display->click apply and see if it works that way.
Nov 16, 2004 #3 D dudewth [H]|G Minecraft Division Leader Joined Jul 13, 2002 Messages 1,976 If you have another monitor, try hooking it up to your second connector and switching the primary driver under desktop properties.
Nov 17, 2004 #5 S spin02 Limp Gawd Joined Aug 13, 2004 Messages 196 I will try all above suggestions. I have been able to get signal through component input, just not DVI.
Nov 17, 2004 #6 M MaMMa Supreme [H]ardness Joined Aug 11, 2004 Messages 6,778 I have a question relating to this, my monitor doesn't have DVI but my 9800 XT does. If I use a VGA spliter to DVI would this increase any performance/?
Nov 17, 2004 #7 S spin02 Limp Gawd Joined Aug 13, 2004 Messages 196 My PE has both VGA & DVI, honestly I can't see any difference. I am running an older monitor. I might be limited by that.
