duron 1.4 to atlon xp - how to do it?
Discussion in 'AMD Processors' started by userjack, Feb 25, 2004.
  1. userjack
    userjack n00b
    43
    Sep 1, 2003
    "If you take a closer look on AMD Duron and AMD Athlon XP processors you will notice only tiny difference: an L2 bridge is not locked on the Duron processor. If you lock it again, everything should work and the processor will have an L2 cache of 256KB"
    how can one do this?
    what tools r needed? (i live in a farm :)) there r no normal computer shops nearby (and i dont have a credit card to order online :((( ), so if u can point to something more accesible itl be great)
    plz heeeelp
    TIA
  2. Mad_Pyro
    Mad_Pyro [H]ard|Gawd
    2,015
    Jul 16, 2002
    The type of paint used to fix the rear window defogger system on cars - it comes in little kits and you should be able to pick some up. It is used to reconnect the traces on the window. This may or may not work for the Duron.
  3. userjack
    userjack n00b
    43
    Sep 1, 2003
    *Mad_Pyro*
    thanks a lot
  4. Spudsdude
    Spudsdude Gawd
    974
    Dec 28, 2000
    i tried this mod on a duron i picked up. (Didn't work)
    Here's a page i found on it.
    http://www.livejournal.com/users/acpizza/271468.html
    Duron 1.6
    Didn't do anything, and even made sure that the contact area was exposed before reconnection.
    Maybe it was just bad luck for me.. hehe.. was worth a shot, with it's cache trimmed off it's dog slow and getting the boot for a new 2400+ mobile.
    Good luck, let us know if ya get it to work.
    Spuds
  5. chile7236
    chile7236 Limp Gawd
    360
    Jun 11, 2003
    just remember, the unlock will not work on post 0339 chips. there are some 0345's, i believe, that have not been superlocked but those are few and far between...good luck...
  6. userjack
    userjack n00b
    43
    Sep 1, 2003
    tnx 4 the help
    do u know a good url w/ info on duron marks(so i can find a pre week 38 cpu :)) ?
  7. chile7236
    chile7236 Limp Gawd
    360
    Jun 11, 2003
