Before you kill this, this is not about helping me fix a Warez copy of XP..
A client of mine brought in his Sons PC with a plethora of problems. You don't even want to know about those. Upon talking to his dad about a few problems I couldn't fix, I asked when they installed XP Home Edition. He informed me the copy his son installed wasen't legit. I told him to stop right there and started laughing. I remember reading some place that MS got wise to the warex versions and instituded some sort of block or what have you on the patching process if a warez machine DLed SP-1... Well, this machine indeed has SP-1 on it, so I ASSUME some problems are caused from this. I told his dad to purchase a copy of XP home edition and if I can't fix it with a new serial number, then at least I'll have a good version to install after a format.
I guess the question I have is, what does SP-1 update do to warez copies in terms of problems? The one have is not being able to get online and as far as I see, everything is working right.
And if your curious, some of the problems I had to fix where 35 bugs found, 42 start up proggies which included some like 5 search helping tool bars and 3 P2P progs, and other spyware things that would render the PC useless when you reached the desktop.. Desktop picture that is, I couldn't get it far enough to see Icons, not even in safe mode. Those are fixed BTW.
Thanks for the help,
-Deez-
-Deez-
