Hello-
I've got a brand spanking new Dual Xeon with HT at work; i.e. I see 4 graphs at the 'pulse window' as I like to call it (task manager). It's easy to see if my model is still running
I use ETABS for stuctural analysis- and have an absolutely enormous model. a 35MB model in ETABS makes about 5GB in analysis files each run. And it's averaging about 8 hours per run.
I've noticed that it doesn't seem to be using both processors/ all 4 logical processors. At full tilt it's using 25% of CPU time.
Anyone have any ideas on how to tweak this badass multiprocessor system for what it was bought for? i.e. how do I get the 25% CPU usage up to 100% when using ETABS? Related- the whole goal here is to cut processing time for my huge model from 8 hours to 2 hours with the same machine and software.
https://www.csiberkeley.com/
As an example, the model is running right now- and it will probably finish at about 6:00 in the morning on Sunday. And any changes that you make require a new run. This isn't a problem for normal models that take about 2 minutes to run, but this is a highly irregular highrise; and they start digging the hole in April- so time is of the essence.
Thanks in advance for any ideas-
