johnnyscience
- Nov 15, 2008
Ok so I have 2 video cards, I thought they were both Asus Nvidia G-Force 9800GT cards and they look almost identical except for a some resistors etc. They have the exact same model #, different serial #'s though obviously.
Is this going to be a compatability problem when running them together?
I know you need the same card to be able to run them at the same time and I had this exact setup work fine for years, but I had to get another 9800 GT because the one went bad.
I thought I got the exact card, spent hours cleaning it up (it was used) and I put them next to each other and noticed some slight differences. One was manufactuered in China, the other Taiwan, not sure if that has to do with anything.
I just hope they will work together so I can run a 3 monitor setup.
