Subzerok11
- Aug 13, 2014
So I have hooked up is one PC monitor and on 4K TV. In the Nvidia control panel I have the Digital Vibrancy set at 65% for the TV. I reconnected my old monitor and for the first time I turned both display on I seem to remember that the TV would only be the one with a Digital Vibrancy set at 65% and the monitor wasn't affected by the setting change. Problem is since I rebooted the PC now the monitor is also affected by the digital vibrancy setting of 65%. I only wanted the TV to use that setting not the monitor too. Anyway to fix this ?
I initially thought that when I set the Digital Vibrancy set at 65% and with the TV only being the one display connected to the PC at the time that the PC would remember the setting change was only for the TV.
