I have 2 hard drives, an 120 gig with XP on it(drive is master), and an 80 gig with Linux(drive being slave). Now when i installed Linux, I installed GRUB on the MBR of the 120 gig. When i boot GRUB comes up with the options of booting into linux or XP, if i select linux it boots fine, but if i select xp nothing happens and i need to reboot my computer.
I think it has to do with my grub.conf file so here it is:
Code:
# grub.conf generated by anaconda
# Note that you do not have to rerun grub after making changes to this file
# NOTICE: You have a /boot partition. This means that
# all kernel and initrd paths are relative to /boot/, eg.
# root (hd1,0)
# kernel /vmlinuz-version ro root=/dev/hdb10
# initrd /initrd-version.img
#boot=/dev/hda
default=0
timeout=10
splashimage=(hd1,0)/grub/splash.xpm.gz
title Red Hat Linux (2.4.18-3)
root (hd1,0)
kernel /vmlinuz-2.4.18-3 ro root=/dev/hdb10 hdc=ide-scsi
initrd /initrd-2.4.18-3.img
title XP
map (hd1) (hd0)
map (hd0) (hd1)
rootnoverify (hd0,0)
chainloader +1
