Dual boot Vista/XP system but the boot loader is broken...help please
Discussion in 'Operating Systems' started by shaolin95, Oct 1, 2008.
  1. shaolin95
    shaolin95 2[H]4U
    2,785
    Jan 5, 2006
    HI!
    I installed Vista 3 times (two different HDDs before) and this time I want it to stay. I am running XP Sp2 and Vista 64 SP1. The problem is, in order to boot to either XP or Vista I have to access my boot device menu and select which HDD I want to boot from. If I dont do it, I will get the OS selection screen but only shows two Vista option and both are broken.
    Its kind of annoying specially since my Logitech G15 wont control the boot menu so I always need a PS2 keyboard connected as well.
    Any ideas?
  2. shaolin95
    shaolin95 2[H]4U
    2,785
    Jan 5, 2006
    Nobody has seen this before?
  3. speedy523
    speedy523 [H]ard|Gawd
    1,187
    Aug 13, 2008
    well you can try a couple of things. if you cant get into any OS at all, use the vsta install dvd and do fixboot, but if you can get into an OS, go and install Vista Boot Pro and run that. It'll redo the bootloader so that you can use the boot selection. Hope this Helps!
  4. CrimsonKnight13
    CrimsonKnight13 Lord Stabington of [H]ard|Fortress
    7,025
    Jan 8, 2008
    Get EasyBCD or VistaBootPro. Make sure you boot the Vista drive & install one of those apps. You can add XP as an option to the boot menu.
    Both apps allow you to install or uninstall the Vista boot loader on any drive of your choosing as well.
