With a dual monitor setup you have always been able to get a background for each by doing one big image with both backgrounds side by side. Then with tile it causes the image to be set full size on the first screen and the right side jumps to the 2nd monitor to give it it's background. Requires image editing to plan right.
Well, in Vista this method is screwed up, instead of tiling whatever image you pick like normal, it seems to make it fit on the first monitor by scaling it down and tile under it, even looks like it's distorted. Actually, when I open this image in the picture viewer it looks squished even thought the thumbnail preview is not.
Is this the next gen operating system where dual monitor is still not supported beyond extend my desktop. The tried and true method of dual background with no extra software ruined? Even the program called Ultramon that is used to add better dual screen functionality to XP had a dual background option that in the end just stitched the two images you pick togethor and sets it to tile, compared to manually doing it in image editing like I do.
This seemed to work in Vista RC1, though, it had a problem too, the tiled image caused some image corruption by kicking around a chunk of the image over a different part.
Hard to explain.
EDIT: Wait I don't think it was distorting things, but just scaling to fit. But you guys know the method right? Say you have two 20.1inch widescreens (same size to make it easier). So each screen is 1680*1050. If you take two backgrounds you want, 1680*1050 each, then stitch them togethor as one really wide image, 3360*1050, set it as the background, then choose tile, the first half would fit on the first monitor, then the other half tiles perfectly to the 2nd monitor, viola, dual background with one image.
Hard to explain.
