Originally posted by kleptophobiac
Very slick looking. I bet it'll beat the BIX2 performance wise as well....
Originally posted by weapon--
the shroud that I am building is a little different than most of the dual 120 shrouds that I have built or used in the past -- it should kick things up a notch on the airflow.
For some time, I have been using 1971 Caprice heatercores when I wanted to use 2-4 120mm fans for some serious cooling power.The problems with the caprice cores (barbed fittings that are a royal pain to get out and odd shaped holes punched into the top tank) led me to search for a different core.
Originally posted by diredesire
nice work giblet (sorry for the thread jack) how did you paint that core? I'm curious as to how you painted the tips of the fins (brush perhaps?) but not the actual 'fins'. Nice color choice, too. Very... RED
Originally posted by topcat989
just picked up mine at kragens today. they wanted 31.99 bastiges - i told the guy screw that autozone has them for $17.99, and low and behold, he pricematched plus 5% looking foward to working on it.....
31.99? ouch - that would have been way too much - I checked with most of the local auto stores and on eghey and all the prices that I got were within a few $$ of each other......
the other project is a bit more large scale - ardawgy's garage shares a wall with his computer room and I could not refuse running copper pipe thru the wall. There is a lot of space in the garage and noise will be no concern. he gave me the go ahead to create a monster so this one is going to be fairly large as a straight H2O loop....but even larger when I finish the 7500 BTU waterchiller that is currently being put together for it on my workbench. Other components: 5 gallon double-insulated res for summer use, 700gph pump and it is switchable from the phase change res to a heatercore secondary loop for winter use... there will definitely be some pics of this one up soon.
Originally posted by mbmadness
This is very affordable. Thanks for the info. What are the heater cores made out of? How do they compare to oil coolers and transmission coolers? Where did you pick up that powerful waterpump? I've been wanting to do some watercooling for some time but it seems expensive. However using the heater core you suggested should cut down costs significantly. Nice find.
With just the edges of the core painted the paint doesn't cause any loss of cooling performance. the side panels and tanks are not the parts that exchange heat so no worries there.Originally posted by amohedas
Does paint affect the thermal dissipation at all???
And what type of paint do you use to paint your core??
update on the 79 core project...
I soldered on some side plates and added a bit of paint.
the shroud is set for this weekend.
pic of course:
I'd like to know what you used for the side plating, and any writeup on the shroud would be appreciated
pic of course:
Originally posted by Gargoyle_Hunter
Is there a radiator that I can do this to for a single fan? Or should I not even mess with the smaller Rad and just go for dual fans?
That is the JR version. The Pro version is gone... And I was going to order mine this weekend
Originally posted by DeViLdUdE
Well I'm lucky to get the last procores at dtek . Ordered 2 of them and 2 shrounds seperately. I have all the WC parts but still need to build a box out from acrylic where I could put those 2 huge a** procores. They are slightly bigger than my PSU(Antec).
Originally posted by AnimeMan
I was just wondering what kind of paint you used? and also what effect the paint has on the heatercore, is it bad for cooling or does it even matter once it dries.
Originally posted by cornelious0_0
Heh, ah well.....maybe I should just "settle" for a DangerDen HWLabs 120mm rad.....seeing as it'll at least fit properly.
