Lord_Exodia
- Sep 29, 2005
Since I got my GTX 980 cards I had intentions of using DSR. It has been quirky trying to get it all to run correctly but to be honest I have a strange setup.
My setup is 3 1080P (1920x1080) in a Portrait NV surround setup running at 3240x1920 @ 120hz.
Here is what I found so far;
DSR works if I disable SLI and run anything from single screen to triple screen Nv Surround.
DSR does Not work with SLi unless I only run 1 screen
So yeah, my issue is I want to run WITH SLi AND triple Screen surround but currently it's glitchy and doesn't allow for that. Tried clean driver installs, tried checking the Registry to figure out which value is for DSR and seeing if I could modify and change something there to get it to work. (no luck)
I also have 2 separate buddies saying that DSR does not work in any capacity with GSYNC, with/without SLI, With Single or multi screen etc...
What's your experience? Please post in Poll and Post a comment in the thread. Any helpful tricks would be appreciated. Thanks for looking.
