I just started to test out my DS3/e6400 combo out and I'm getting conflicting temp readings. With Core Temp 0.95 I'm getting 40c at idle and when running Orthos after 2 minutes or so I'm seeing temps in mid 60s. With easytune5 I'm showing around 30c at idle(didn't have it running at load). So what program should I trust. I did up my cpu voltage to 1.3500v(showing 1.3300 ineasytune5 ) as i'm using the OCing guide Bill Parrish posted here. I am using the stock intel hs/fan with as5 and it is mounted properly. the fan speed is only about 1700rpm is that right?? . I did disable auto fanspeed control in the bios. I'm not OCing yet, still at stock speeds testing things. Thanks
**Edit**
Everest and speedfan are also showing 30c ish at Idle too, so I'm starting to think it must be an issue with CoreTemp. In the bios it's showing mid 30s
**Edit**
