I just went back to F10 BIOS because I bought the Buffalo Firestix PC8000 memory with the Micron D9's
I am a little unclear about what using Option 1 vs Option 2 does in the F10 BIOS. Has anyone tried this and can tell me the difference between the two settings? I am trying to get the most out of this memory which is guaranteed to run at 500 MHz and that is before you overclock it. Thanks.
Right now I am using the default, Option 1, because I don't really know what option 2 does or if I need it. The help says something vague about try this if you need to go above 500 MHz
