I've been having issues with this for quite some time and while I've found people with similar problems, I've never found a good answer.
My issue is this:
I have a 144hz and a 60hz monitor, and I'm unable to run things in borderless windowed without having stuttering/dropped frames. Disabling Aero has helped to a certain extent, but I'm unable to use Nvidia shadowplay to capture instant replays with it disabled. (I'd ideally like to be able to capture matches I've just played in Tekken 7 at will)
I've also tried putting the secondary monitor on the integrated GPU, but that seems to make the issue even worse.
Setup:
Gigabyte Z170 UD5
16GB DDR4 3000
GTX 1080 FE
i7-6700K
Windows 7 64 bit
My issue is this:
Setup:
Gigabyte Z170 UD5
16GB DDR4 3000
GTX 1080 FE
i7-6700K
Windows 7 64 bit
