friend'scatdied
- Feb 20, 2005
I was dismantling my Shuttle this evening and foolishly dropped my PNY XLR8 DDR2-800 stick. It actually made two falls -- one about two feet onto my desk, where it bounced and fell an additional 3 feet onto the floor. Here's a picture of the part that concerns me -- I'm not particularly sure if this was there before the drop (sorry for the poor quality, dorm lights are dim and my 3GS sucks):
I cleaned the RAM with 91% isopropyl alcohol and let it dry for about a half hour to be sure. I booted up the machine with JUST that one stick in (as opposed to all four sticks I normally used). It booted just fine. I ran a memory check through POST and for some reason the memory check went all the way to 8GB and kept looping back down to 0 and going over in an infinite loop (no test failed, no stopping, no nothing). The only difference I had from the last POST was going down to 1x2GB of memory and removing my GTS 250 (so the GMA X4500HD, with shared memory, was being utilized). Could the BIOS have still been thinking I had 8GB in for whatever reason?
Anyway, I booted into Windows just fine and ran IntelBurn on Max stress level (most RAM utilization) for the default 5 cycles. It ran fine, and temps and voltages looked normal through Everest.
For clarity the stressed-looking whitish region does not actually infringe on the gold contact in that area. The contact is completely intact going by my eyes. I have NO idea whether this was there all along or a result of the drop. There is no other visible "damage" to the sticks. Should I be worried, or am I just being paranoid and is DDR more resilient than I'm thinking?
