Xaero_toast
- Dec 29, 2008
Does anyone know where to find a windows 7 driver for a geforce FX 5950? It seems nVidia dropped official support for the FX series of cards before Windows 7. I can get a Vista driver to install, but the performance is abysmal.
I have in the past gotten cards to run on drivers after support had been dropped with a simple edit to the inf file, but comparing a current, and a last supported inf file, it seems the structure of the inf file has changed slightly.
Suggestions to replace the card will not be helpful. This is an old pc, and the entire project is only (marginally) worthwhile if it can be made to work with the parts on hand.
