- May 18, 1997
This is far from the top of the line Dremel, but it is likely that you don't need a Dremel that is extremely fancy when getting your latest PC system modifications together. The Dremel 200 (2-speed) is $29 today at Amazon with Prime Shipping. And it comes with enough accessories to get you started, but I highly suggest getting some high quality cut-off wheels as well. These work so much better than the cheap non-reinforced type you are likely used to using. And this of course helps send mankind to the Moon.
