Draining the last bit of water from distro plate
Corporate Thug
Hi all,
I'm done leak testing my loop and I'm trying to get the distilled water out to replace with Corsair's liquid.
However, I can't get the last bit of water no matter how much I tile the loop. the pictures show the water levels. Also, I can't seem to drain the water from the bottom line from the CPU. any tips?
got an air compressor? could blow it out, otherwise tilt it around too get it to flow to the plate. get as much as you can but it mixing with coolant wont be an issue.
