Drag and drop files onto RDP
Discussion in 'Operating Systems' started by thebaest, Dec 15, 2009.
  1. thebaest
    thebaest Limp Gawd
    183
    Oct 2, 2009
    noob question.. How do you set up to where you can "drag and drop" files from your local OS onto your RDP OS as seen in my awesome mspaint drawing? I am fairly familiar with the group policy editor and im sure its something in there that will enable it for me, but I'm not sure what I am looking for. Im sure its not listed under "drag and drop" :p
    [​IMG]
  2. tesfaye
    tesfaye 2[H]4U
    3,419
    Apr 17, 2003
    As far as I know, the feature does not exist for any version of the Microsoft RDC.
  3. thebaest
    thebaest Limp Gawd
    183
    Oct 2, 2009
    I swear I have seen people do it, but maybe I was just seeing things. Its kinda like just sharing the clipboard... just with files :D
  4. J-Will
    J-Will [H]ard|Gawd
    1,723
    Jan 10, 2009
    I do not know of a way to do that either
  5. J-Will
    J-Will [H]ard|Gawd
    1,723
    Jan 10, 2009
  6. disuse_nc
    disuse_nc Limp Gawd
    208
    Apr 17, 2007
    You probably saw VNC or something similar for Remote Desktops... or a VMWare window.
    RDP by itself only lets you connect to existing drives, but not drag and drop like you are trying to do.
    It also seems slow but.. at least it works.
  7. tesfaye
    tesfaye 2[H]4U
    3,419
    Apr 17, 2003
  8. thebaest
    thebaest Limp Gawd
    183
    Oct 2, 2009
    that should actually be sufficient, thanks a bunch guys, you rock!
  9. Rabidfox
    Rabidfox Limp Gawd
    282
    Oct 6, 2005
    open remote desktop "mstsc.exe", select options, select options, go to "local resources" select "more", check drives. When you connect they'll show up in explorer, sheesh, what's wrong with that?
  10. SpaceHonkey
    SpaceHonkey Gawd
    983
    Jan 25, 2007
    Which is what was covered in the link provided - if you read it.
    Also, this topic has nothing to do with virtualization.
  11. Rabidfox
    Rabidfox Limp Gawd
    282
    Oct 6, 2005
    1) he said for vista or better, which is not true.
    2) exactly, why is this in virtualization?
  12. horndog
    horndog [H]ard|Gawd
    1,591
    Aug 18, 2001
    I know you can copy and paste text, but never tried a file.
  13. IntelOwnz
    IntelOwnz Gawd
    710
    Oct 29, 2006
    if you map your drives, you can drag and click files from the Virtual/Remote machine, into the host, using RDP
  14. Wiseguy2001
    Wiseguy2001 2[H]4U
    3,453
    Nov 28, 2001
    Damn, I thought the [H] had a wealth of knowledge...
    Yeah you can drag and drop files in/ out of an RDP session easily by enabling clipboard sharing (Local Resources -> Clipboard checkbox). This requires RDP version 6.2, so is available of Vista/ Svr08 and up.
    PS: File redirection is cool too, both of these have their pros/ cons, so use both!
