Downsize radiators for new Evolv X?
Discussion in 'Water Cooling' started by Nirad9er, Aug 31, 2018.
  1. Nirad9er
    Nirad9er 2[H]4U
    2,411
    Feb 18, 2004
    So I have a Alphacool Nexxxos XT45 420mm and EK coolstream XE 360 both on push pull at around 1300rpm.
    This so cooling my 7820x (4.7ghz) and 1080ti SLI over clocked.
    This is in my Thermaltake View 71 but I really want to get the Evolv X which would force me to use my 420mm push pull and a 280 slim in push only. For the slim I'd consider a nemesis GTS 280 which by my research would lose 70-100w compared to my 360.
    How much would this impact my temps in my current setup?
    Is a 420 and 280 slim adequate for my setup in the new Phanteks Evolv X case?
    Thanks!
  2. Dermen
    Dermen Limp Gawd
    314
    Oct 10, 2017
  3. Nirad9er
    Nirad9er 2[H]4U
    2,411
    Feb 18, 2004
  4. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,580
    Apr 5, 2016
    The rule of thumb is 28,800^2mm (a single 240 rad) of radiator area per overclocked component.
    With two, you "need" 57,600^2mm.
    With a 280 and 420, you'll have 98,000^2mm.
    Another way of looking at it is this: you'll be swapping a 360 (43,200^2mm) for a 280 (39,200^2mm), meaning a drop of 10% surface area off one of your radiators.
    As I said in that other thread: if that much of a change is enough to wreck your temps, you're cooling on the ragged edge already.
  5. Dutt1113
    Dutt1113 [H]ard|Gawd
    1,451
    Jun 30, 2005
    So is this going to be just adequate/ "ok" or will this be good cooling?
  6. VanGoghComplex
    1,580
    Apr 5, 2016
    Adequate/ "ok" would be 57,600^2mm.
    You'll have 98,000^2mm.
    Everything is subject to personal preference, of course, but that would be "good cooling" for me! :D
    Edit: disregard my previous math... I didn't catch the SLI in your post.
    This places your "rule of thumb" radiator area requirement at 86,400^2mm.
    You'll still be over that value, but not by quite as much.
