Relevant [H]ard|Ware:
DFI LanParty NFII Ultra B (SoundStorm FTW!)
35W 2400+ Mobile Barton (2.0GHz/1.42V for now)
1GB RAM
AIW 9700 Pro
PVR-250
160GB Hitachi 7K250
NEC DVD-RW
Sony DVD-ROM
XP Pro
Yamaha RX-V1400 w/ 5.1 sound
Hitachi 65G500 65" CRT HDTV
Install was a breeze. Drivers, ATI MultiMedia Center, DVD playback software installed without a hitch. ATI HDTV support is great with one bug. Catalyst Control Center picked up my HDTV right away, and 1152x684 looks great with no overscan. However, it doesn't remember this setting on reboot and goes right back to 800x600 Any ideas what's going wrong? I'm running WHQL Cat 5.13 /w CCC - will the Omegas fix this?
DVD playback has been fabulous. I can enjoy either 480p w/ hardware acceleration, or 1440x960 FFDShow post processing. The 5.1 passthrough over S/PDIF cranks, and the audio quality is much better than what is delivered by my set top DVD player. The 2.0GHz Barton is kind of limited in terms of FFDShow power, as upscaling to 1440x960 and applying some basic noise reduction rockets CPU use into the 90+ percent range. IQ is fantastic, but can I get some of my CPU time back, and what works for you guys on FFDshow?
Gaming so far has been excellent. UT2004 looks great in 1152x648 (same res as desktop, only had to edit ini to get it work) WideScreenGamingForum made this a cakewalk.
Also, any suggestions on a PVR front end...Is SageTV worth the bucks, or should I just use one of the freebies?
I may put another PVR-250 and a pair of Samsung HDDs in it, but the rest of the hardware probably can't be changed, as I'm poor.
1GB RAM
AIW 9700 Pro
PVR-250
160GB Hitachi 7K250
NEC DVD-RW
Sony DVD-ROM
XP Pro
