- Aug 20, 2006
The Doomsday Seed Vault (or, less dramatically, the Svalbard Global Seed Vault) was established to preserve a wide variety of plant seeds in the event of some global apocalypse. Unfortunately, so-called permafrost actually melted this week and the resulting water breached the entrance of the facility. Luckily, no seeds were harmed, though this scare has jumpstarted a plan to reinforce the area with waterproof walls and ditches to thwart against future surprise pourings. This is probably just me, but it reminds me of a giant Wii.
Statsbygg, the Norwegian construction group behind the vault, has outlined "technical improvements" to keep the entrance safe. It's building waterproof walls and ditches to channel water away, and it's moving electrical equipment out of the entrance to avoid creating a source of heat. The vault will also take fewer visitors to reduce body heat levels -- even that small amount could make a difference. With that in mind, Statsbygg stresses that the seeds themselves have "never been threatened." The mountainside that holds the seeds themselves will keep its permafrost -- the builders just hadn't expected that the permafrost near the entrance would refuse to re-freeze after a decade since construction.
