Domain help
Discussion in 'Networking & Security' started by Jeffman, Feb 8, 2018.
  1. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    Hey guys/gals,
    I'm lost and think I need some advice.
    At work, we're replacing a few computers. Going from Windows 7 to Windows 10.
    2 of the computers, the primary users aren't having one of the drives mapped automatically. There are 3 mapped drives, all on the same server, all mapped by Group Policy. 2 of those map fine, the other one fails. Net Use show's it's mapped, but when we try to pull it up and enter their credentials, it says "Access Denied".
    I can log into these computers as the domain admin, and have no problem accessing the drives.
    I can log in as another user, and have no problem assessing the drives.
    Permissions never changed. It worked fine on their old Windows 7 computers.
    I know the computer can access the server and drives fine. I know that these users can access the drives from non-Windows 10 computers.
    Am I going insane? What am I missing here?
    Any help is appreciated. Thanks a ton!
  2. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,518
    Dec 23, 2001
    I would blow away the user profile and kill it from the registry. Have the user relogin and see if it maps right. I would also look at the event logs for gpo failures etc... Also what version of smb is enabled on the file server? If only lower versions are turned on then is can also cause issues
  3. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    ^Is that necessary when it's a new computer and a new account for them already?
    I'm not sure on SMB versions...I'll see if I can check. Would that matter if other users can access the drives from the same computer?
    Sorry if these are stupid questions...I'm not great with domains...I know enough to do most of my job without trouble.
  4. Vengance_01
    5,518
    Dec 23, 2001
    your other machines are windows 7 which has lower versions of smb enabled. On windows 10 it could be different. I am more of infrastructure/server guy but I have done my share of desktop support. Just trying to give you some ideas.
  5. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    ^It's working on other Windows 10 machines with no problem. Same group memberships too. It's something with the user, not the computer. But other users in the same groups on the same computer have no problem...and the user doesn't have anything that would *restrict* them set in permissions anywhere.
    That's why I'm so confused. I don't see a single reason or point where it failed. It just denies the access to them, but there's no reason I can see.
  6. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    I should add, in Net Use - the drive is mapped. But this user just can't access it.
  7. Vengance_01
    5,518
    Dec 23, 2001
    Maybe kill all sessions on the file server. If this user logs into another 10 machine does the issue follow them?
  8. Spartacus
    Spartacus [H]ard|Gawd
    1,848
    Apr 29, 2005
    Are you using roaming profiles by chance?
  9. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    ^No. I just remoted into another Windows 10 computer using their account, and it worked as it should. Same network, same subnet, same user, just a different computer.
    I can log into the computer in question as another user in the same group (not myself as the domain admin), and it will work. But for this user it won't.
    I have this problem with 2 users and their new computers.
    No roaming profiles.
  10. Spartacus
    1,848
    Apr 29, 2005
    Are they local admins?
    I agree with the post above, something's wrong with the user profile if the same user account works on one but not the other.
    Try unjoining and then rejoining the machine on the domain.
  11. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    They are local admins on their computers.
    On the first machine I tried a disjoin and rejoin on the domain. No go.
  12. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    Wow...it works if I leave out the drive letter I'm mapping and just add in the server name and folder.
    Which is weird because this is what Group Policy is set to do. The Net Use drive mapping was correct. I always add the drive letter when I manually map it.
    I don't get it. I'll have to try a few reboots and see if it stays.
  13. Spartacus
    1,848
    Apr 29, 2005
    Try turning off hidden empty drives.
    Example: You are trying to map "H" drive but the machine has a multi-card reader with a hidden empty "H" drive already.
  14. Biznatch
    Biznatch [H]ard|Gawd
    1,951
    Nov 16, 2009
    Did you test the machine with GPResult? It will tell you why a GPO failed to apply.
  15. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    I didn't. I think the GPO applied as it should have, it just claimed the user didn't have rights to the drive, when they really did.
    It kept working all through last night with the mapping leaving out the drive letter. I'll test it more today and see how it reacts...but I think it's solved. I still don't understand why it broke in the first place.
  16. Vengance_01
    5,518
    Dec 23, 2001
    What did you do?? Share to help others
  17. Jeffman
    Jeffman Gawd
    888
    Jul 23, 2008
    See post #12 above - I left out the drive letter when mapping. Instead of mapping \\server\drive\folder I just mapped \\server\folder and it worked.
