I've had nothing but problems on all the computers I've installed Win7 on. Everything was fine for maybe 2-3 weeks, but after that, nothing but mayhem, especially on our laptops.
Everything has Windows 7 Enterprise x64 with legitimate keys. no cracked bullshit here.
Desktop: Worked fine for a while. Last week, it just refused to boot up all the way. It went to the welcome to windows screen and then just restarted. I got rid of all OC and reseated shit, no help. It randomly fixed itself tho lol.
My laptop (in sig): As soon as I got the laptop, I wiped and installed Win7. Major issues started last week. First off, some background. It's constantly plugged into my monitor via VGA, ethernet, and a belkin usb hub with keyboard, mouse, sound card attached.
- The biggest issue is that after like an hour or two, anythign connected via USB just stops responding. The only way to solve is to restart the computer; switching usb ports or replugging does not help. I turned off every USB power saving setting in device manager, but it did not help. WTF?
- This leads to another issue. At this stage, if I try to shut down the computer it never finishes, so I have to hard turn it off with the power button. If I want to restart instead, no dice. WTF?
- Another issue is that I can no longer hibernate teh computer. When I select the option, it basically like tries to hibernate or something, but never finishes. I left teh computer alone for 20 minutes and it wasn't done. I only had like one program open, so that shouldn't cause an issue. Same thing happens with standby....
- It completely died for some reason for a while. It wouldn't turn on (not a battery issue), nothing would work at all
- Finally, it came to life, sorta. Laptop screen was blank... However, it turned out that if connected to a monitor, you could use the laptop screen, so it isn't dead. And it's not a setting thing either from what we can tell. We tried every combo possible to get the laptop screen to work if no monitor was attached, but to this day, it still refuses to work. WTF????
