Child of Wonder
- May 22, 2006
I'm in the market for a new laptop but am tired of toting around a 15" 6lb beast when I travel. Using a laptop that large just does not work on an airplane. So I've been looking at 14" and 13.3" laptops but am exacerbated by the fact that every manufacturer has a hard on for 1366x768 resolution. I need more real estate on my screen than that. To top it off, very few laptops in the 14" range have a dedicated GPU either.
Here are my requirements and I seem to be totally unable to find a laptop that satisfies them. I turn to you, [H] gurus, for your help. Anyone seen a laptop that meets the following criteria?
- Intel i7 Ivy Bridge CPU, quad core preferred
- RAM expandable up to 12GB+
- Option to replace primary HDD with a SSD on my own (already own one)
- Dedicated GPU that can play modern games (NVIDIA 640M or higher)
- Screen resolution of 1600x900 or higher
- No larger than 14" screen
- Backlit keyboard preferred
- Greater than 4 hours of battery life
- Under 5 lbs
- Under 5 lbs
