- Jan 12, 2004
On deciding to stay where I am for a few more years, I decided to wire up the house and rack mount some of my equipment here. I've never wired a structure before, or even made my own cables, but it sounds like fun and I thought I'd give it a whirl. So this is everything I'm getting, I was wondering if you guys would let me know if it all looks good or if you have any suggestions. Max cable length should be ~150 feet.
Tripp Lite Cabinet
24 AWG Cat 6 550Mhz STP Solid
Tooless Keystones
Ratcheting Crimper/Stripper
Solid Cable Plugs
Now in addition to the in-wall stuff I'm going to be cutting some shorter cables to go from the larger wall plate under the cabinet into the switches. Should I get stranded for that (and swap to stranded connectors) or is it fine to use solid cable there?
Anyway, like I said, I've never done this before, but I wouldn't mind the experience and it sounds like fun. Just trying to make sure I don't make any serious mistakes. If you take the time to read/give feedback, thanks!
Tripp Lite Cabinet
Tooless Keystones
Solid Cable Plugs
