Does the AOC-SASLP-MV8 work with 4TB drives?
Discussion in 'SSDs & Data Storage' started by SKiZZ, Oct 7, 2012.
  1. SKiZZ
    SKiZZ Limp Gawd
    511
    Mar 9, 2000
    Does the AOC-SASLP-MV8 (first model) work with 4TB drives? if not is there something similar that works with WHS v1?
  2. djflow195
    djflow195 [H]Lite
    102
    Sep 6, 2011
    WHSv1 does not work with any drives larger than 2TB unless you do some serious hacking.
  3. SKiZZ
    SKiZZ Limp Gawd
    511
    Mar 9, 2000
    Ahhh, well I could stick with 2TB drives. I am using a Norco 4020 so I have the room.
  4. Erasmus354
    Erasmus354 [H]ardForum Junkie
    9,461
    Mar 12, 2004
    guhhhhhhhh
    This.
    I tried to get my WHSv1 to work with larger drives and I regret it immensely. Nothing worked right and I had to wipe out the entire install. Ultimately for me it came down to WHSv1 and motherboard firmware not playing nice together once I started hacking things. There are good guides out there on how to do it, but it is certainly nothing easy to do. I would recommend just keeping it simple and sticking to 2TB drives.
  5. Bigdady92
    Bigdady92 [H]ardness Supreme
    5,773
    Jun 20, 2001
    Dump WHS and get a different OS that supports it and does the same thing as WHS. Check out the threads on ZFS and you'll be amazed.
  6. hotcrandel
    hotcrandel Gawd
    781
    Feb 26, 2010
    I've had nothing but issues with that card, its sitting on the shelf right now. Using LSI cards in IT mode removed all my blue-screen woes.
    This is in a Server 2008 R2 x86 setup on an atom board with max 2gb memory, with Flexraid.
    And I don't believe it supports bigger than 2TB drives. There is a second version of the card that DOES with firmware updates. Dunno if you have V1 or V2
  7. FrostBite
    FrostBite [H]ard|Gawd
    1,082
    Jun 2, 2004
    AOC-SASLP-MV8 does support 3TB+ with firmware update. It's what I am currently using.
  8. cantalup
    cantalup Gawd
    758
    Feb 8, 2012
    I do not think so.. :|
  9. FrostBite
    1,082
    Jun 2, 2004
  10. cantalup
    cantalup Gawd
    758
    Feb 8, 2012
  11. FrostBite
    1,082
    Jun 2, 2004
