my 620HX has 6pin PCIE connectors with an extra 2pin on the same line, im looking at it right now.As per title as my HX620 doesn't have one.
the theory i am running on is if my psu doesn't have an 8 pin pcie cable then it isn't good enough! I'm gonna have to buy a new one from my 9800gx2
You can't be serious? HX620 can't run 9800GX2? HX620 can even run 8800GTX in SLI.
I doubt there is a need for the 8pin connector anyways
This has been OFFICIALY confirmed that it will need 8 + 6 so i really dunno what are you talking about.
My first Corsair 620HX I bought a good few months back did not come with any 6+2 pin modular PCI-E cables either, but my second one (that I bought within the last month) did.
So the OP isn't going crazy, they probably added them in later revisions.
Call Corsair and I'm sure you'll get one or two.
On the question of the cable i have seen cables that convert 2 6-pin sockets to one 8-pin socket.
Because power requirements increase.
Aren't the extra pins just 2 grounds anyways?
They are black wires in the pics. That's weird. Why would they do that?
Yes the additional PCI-E power pins are more grounds. However there is one possible additional difference. The specs for a standard 6-pin just require the first and third pin to be +12v. Most of the time the second pin is +12v powered on a lot of power supplies. The 8-pin specs require the second pin to be powered along with the two additional ground.
The BFG 9800x2 also comes with the adapter it appears. http://www.newegg.com/Product/ShowI...ch+GeForce+9800+GX2+BFGE981024GX2E+Video+Card
I'm confused now.
I've seen 8-pin adaptors that have one or two 6-pin connectors.
Why? Do you really need two?
Why did they even put an 8-pin connector on the card anyway?
