Does PCI wireless card has better signal than embedded wireless module inside PC
Happy Hopping
ASUS PCE-N13 Wireless Adapter IEEE 802.11b/g/n PCI Express 150/300Mbps Transfer/Receive Rate 64-bit/128-bit WEP, TKIP, and AES WI-Fi alliance WPA, WPA2 - Newegg.com
I randomly pick the above. It has 2 antenna. Is this card gives a better signal than a motherboard that has an embedded Wifi module?
because the situation I was at today is, these folks has a toshiba all in 1, which comes with an embedded wifi module in that All in 1. The wireless router/Cable modem is at the basement, and some times they lost signal.
So I'm thinking of something like Linksys WRT1900AC that has 4 antenna, and perhaps source out a signal booster. But if that does not work, it would be time to get a real PC that c/w PCI wireless card.
Do you guys think there is a sizeable gain on signal strength on these PCI wireless card vs. embedded Wifi module on motherboard?
Vengance_01
I would try power over Ethernet. But if you must use wifi the all in one probably has its antenna around the screen. I would look at range entenders. They are getting cheap where they just act as an access point and will allow you to extend their coverage
Happy Hopping
I saw LInksys has a model call RE6400, and they said they work w/ any brand router. Using WPS button. But I don't know if that's secure wifi or not
pendragon1
KISS!
upgrade the antenna strength instead of adding more electronics to complicate things. if the modem/router has antennas you can upgrade those too.
