Does having a large hosts file affect network or hardware performance in any way?
Discussion in 'Networking & Security' started by viivo, Jan 30, 2019.
  1. viivo
    viivo Gawd
    915
    Sep 7, 2005
    Just curious as I don't know how or when hosts is utilized or if its always in memory. The adblocker I use ([H] and related adservers are whitelisted of course) increases the hosts file size to nearly 3MB from the default 1KB. For a single, every day PC, does it matter at all?
  2. FNtastic
    FNtastic [H]ard|Gawd
    1,171
    Jul 6, 2013
    I'm going to guess it's negligible. People do the same thing on phones, which are typically much less powerful
    viivo likes this.
  3. Dead Parrot
    Dead Parrot 2[H]4U
    2,260
    Mar 4, 2013
    It gets looked at for each new DNS lookup. For average browsing, doubt you will notice unless the PC is really CPU bound or insanely short of RAM.
    viivo likes this.
  4. tedych
    tedych Limp Gawd
    260
    Jan 18, 2013
    I wouldn't keep so large Hosts file. Maybe if the router supports custom DNS records... but if this is the easiest for you case, I guess it wouldn't hurt too much. I think queries to hosts file are not cached so everytime the OS would query it. It's known for its less-than-ideal performance and effectivenes in the DNS chain though. If you don't feel some performance hit then it's Ok. Still, being that large I would use other means. Most of the case one doesn't need so many hosts blocked. I use content blocker in the browser where I can use wildcards and regexes where with few rules I can block enormous amounts of content. Hosts file (at least on Windows) does not support wildcards and is very inefficient to use as content blocker unless you want to block several concrete domains.
    viivo likes this.
  5. RogueTrip
    RogueTrip 2[H]4U
    2,771
    Feb 22, 2003
    If you haven't. Disable dns services in windows services.msc or else...
  6. HammerSandwich
    HammerSandwich [H]ard|Gawd
    1,095
    Nov 18, 2004
    Well, Pi-hole uses almost nothing with large lists, so...
