Teenyman45
- Nov 29, 2010
I can't readily control have the boost and fan features on my laptop without the Crate software, otherwise I'd uninstall it again.
https://github.com/seerge/g-helperI can't readily control have the boost and fan features on my laptop without the Crate software, otherwise I'd uninstall it again.
One advantage is if you have multiple ASUS components and peripherals you only have to run Armoury Crate to control them all.Just wondering. I have read here and there that Armoury Crate is buggy. What benefit does Armoury Crate give you? So far, I just download drivers from the ASUS website and then install them one at a time.
Like Fragglestick car. ;-)Armory is a stockpile of fighting weapons, tools, etc. in English. So they're calling the product an arsenal of computer utilities.
Strix is just a made up name .
Is there a free version?nope, using signalrgb.
There is, but imo the software while supposedly good, sucks donkeyballs.Is there a free version?
Try Openrgb?There is, but imo the software while supposedly good, sucks donkeyballs.
Is there any combination of ASUS hardware/peripherals that actually runs Armoury Crate smoothly? It looks like you're running a full-ASUS build, so does it work better when you're not also running iCUE or Gigabyte RGBFusion or other apps?One advantage is if you have multiple ASUS components and peripherals you only have to run Armoury Crate to control them all.
This Gigabyte RGBFusion looks interesting. Would it work with an ASUS mboard?Is there any combination of ASUS hardware/peripherals that actually runs Armoury Crate smoothly? It looks like you're running a full-ASUS build, so does it work better when you're not also running iCUE or Gigabyte RGBFusion or other apps?
Yes, I have had no issues with the combination in the screenshot. Recently replaced the Claymore II with an Azoth. I am not running any other fan or RGB apps because there is no need to.Is there any combination of ASUS hardware/peripherals that actually runs Armoury Crate smoothly? It looks like you're running a full-ASUS build, so does it work better when you're not also running iCUE or Gigabyte RGBFusion or other apps?
So what is your config , including everthing controlled by AC. Stuff that can't be controlled by AC?I have run it for years. 0 issues. I am floored by all the negative comments.
Likewise. Although I use the lighter version on my RTX 4060 laptop - GHelper. Great software.I have run it for years. 0 issues. I am floored by all the negative comments.
Would GHelper work on an ASUS ROG motherboard, to install drivers downloaded from the ASUS website?lighter version on my RTX 4060 laptop - GHelper.
Looks like it is only for ASUS laptops.Would GHelper work on an ASUS ROG motherboard, to install drivers downloaded from the ASUS website?
Small and lightweight Armoury Crate alternative for Asus laptops offering almost same functionality without extra bloat and unnecessary services. Works with all popular models, such as ROG Zephyrus G14, G15, G16, M16, Flow X13, Flow X16, Flow Z13, TUF Series, Strix / Scar Series, ProArt, VivoBook and many more!
Bummeroonie.
Strix is a bird from classical era mythology. A bird of ill omen if that says anythingArmory is a stockpile of fighting weapons, tools, etc. in English. So they're calling the product an arsenal of computer utilities.
No, RGB control is the only reason anyone would need its' contents and that isn't worth the trouble. I shut off Armory Crate in the BIOS...Just wondering. I have read here and there that Armoury Crate is buggy. What benefit does Armoury Crate give you? So far, I just download drivers from the ASUS website and then install them one at a time.
