ComputerBox34
- Nov 12, 2003
Does anyone know when PCIE 5.0 drives are dropping? Haven't seen much news about it since August. Was hoping it would line up with AM5 and X670 dropping.
I just checked. AMD 7000s have PCI-E Gen 5, unless I'm misunderstanding the specs. https://wccftech.com/roundup/amd-x670e-x670-motherboards-asus-asrock-msi-gigabyte-biostar/Only thing I did find was:
For this year (2022) and next year, most manufacturers will concentrate on the incumbent PCIe 4.0 SSDs. Silicon Motion’s CEO, Wallace Kou, says that the reason for the delayed market entry is partly due to the fact that other key players in the industry, namely Intel and AMD, are still upgrading and releasing PCIe 4.0 CPUs. Mr. Kou also clarified that they are planning to launch their 3rd iteration of PCIe 4.0 controllers in 2023. That is before they move to PCIe 5.0 in 2024.
Yes the question since alder lake release is when does consumer grade PCI 5.0 ssd drive will be released.I just checked. AMD 7000s have PCI-E Gen 5, unless I'm misunderstanding the specs. https://wccftech.com/roundup/amd-x670e-x670-motherboards-asus-asrock-msi-gigabyte-biostar/
I don't much care about Intel CPUs any more.
Shuckin' an jivin'?Sho Nuff masta of Harlem wants to know...what possible need do you have for it? Gaming certainly will be fine on gen 3 or gen fo. Nahwhaimsayin shunnnnn?
Well shunnn....if you gon be a shuckin an a jivin, you gon need pcie 9456. Dat be in da year 2000 /conan. Knowhaiamsayin? Just enjoy yo shit son! Don't be a worryin bout no pcie5!Shuckin' an jivin'?
Could be issue to make them fit size-power-heat wise like mentionned just above:So after almost a full year of companies announcing their PCIE 5 drives and talking about sparkles and rainbows that they'll provide, there still isn't a single one available. What's the deal? You'd think someone would want to be first no matter what. Is there something amiss?
25110 form factor did seem to be common on the latest z790 and x670-x670E boards, maybe there are some coordination about the challenge to make them fit on regular slot.My guess is that PCIe 5 devices will first appear in the server/enterprise market in form-factors (
Iron out the PCIe 5 bugs with consumer silicon, so the server silicon works mo better. Server buyers expect stuff like that to work.Not sure why Intel and AMD were so eager to jump to PCIe 5 in their desktop/laptop platforms (marketing bullet points aside). PCIe 4 was just starting to become commonplace. Nvidia and AMD haven't even moved onto PCIe 5 for GPUs yet.
Nope, typically the opposite. Tech usually trickles down, not up. Huge datacenters and other large enterprises are willing to pay huge premiums for the latest tech that might gain them any advantage and/or allow them to better utilize their existing resources. The average person walking into Best Buy is much more cost-conscious, and typically isn't going to really care much about the minutia of PCIe versions.
What is your definintion of "best?"Misleading thread.
Intel has best nvme.
Max transfer speed
File transfer over 20gb...
Optane 4life
I can edit video with 970 and 980 pros in external enclosuresRegret going 980 pro.. Fuck
There is a massive difference between the best SATA SSDs and the lowest-end NVMe PCIe 3.0 SSDs.For most general desktop and laptop workloads, outside of synthetic benchmarks you will see essentially zero real-world difference between NVME 3,4 or 5 (or even SATA.) If you do see a difference it will come at significant increases in $$$$ vs time saved.
If you aren't seeing a difference, then you aren't doing anything even remotely disk intensive other than booting your OS.
Which is precisely what I said. For most people with general desktop or laptop workloads, outside of synthetic benchmarks they will likley see little to no difference. The additional, significant $$$ they will expend for the latest and greatest in this one particular use case is not worthwhile for those people. For enterprise workloads or workstation/prosumer uses, the differences can range from as listed above to significant uplifts, it depends on your use case.There is a massive difference between the best SATA SSDs and the lowest-end NVMe PCIe 3.0 SSDs.
The SATA protocol has been exceeded by what these drives and controllers are capable of, and a high-end NVMe PCIe 4.0 SSD will even far outshine a now older NVME PCIe 3.0 SSD.
Even my Raspberry Pi CM4 had a massive uptick in performance with NVMe PCIe 2.0 1x over SATA III, despite the throughput limitation on both.
