does anyone know this monitor? Dell ST2210B
4LC4PON3
DERP!
I decided to sell my Hannspree 25 inch that I had just because I wanted something different. I know this isnt an IPS monitor but im wondering does anyone know or use this monitor? Its a Dell STB2210 that I got at bestbuy for 179.99
http://www.bestbuy.com/site/Dell+-+...9352.p?id=1218170032082&skuId=9769352&st=Dell Monitor&cp=1&lp=4
The one problem im having is that the monitor's colors seemed washed out unlike other monitors ive used. I turned RGB on my PS3 on Full, Im hooked up HDMI, I have the Contrast on the Monitor at 90. It does look good but Compared to my hannspree 25 it doesnt fly. its set on 1080p on the PS3.
is this monitor one of Dell's pretty much low end monitors? any other suggestions maybe im missing a setting? if anyone uses this monitor some help would be cool :). I read alot of reviews at many difference places and everyone liked the monitor. most people said Excellent blacks and Vibrant colors but I just dont see it.
I just figured this out. I noticed the Sharpness on the monitor when its preset is set on 30 wich makes it Semi Blurry and does show color loss. I put it on 100 and Bam made a Huge difference.
Quick question on this monitor; I just ordered 3 of these for gaming; can you tell if they have mounts on them so I can hang them on a single stand or no.
Thanks mate,
