Technically, you're overclocking the CPU to run it at 1600 mhz speeds, but yes, you should be able to run it without any problems.
nein, its just a multiplier change so that the ram runs at ddr3 1600 though you are putting more stress on the CPU-NB, but most am3 motherboards support it. though 1866(OC) is about the most the x6's can do. its the same thing with intel's i3/5/7 pre SB which only officially support 1333 or 1066(can't remember). but you obviously can run up to DDR3 2000 if the motherboard supported it.
Don't bother. It supports the faster ram, but the memory controller is already saturated with good DDR3 1333:
http://www.behardware.com/articles/814-4/ddr3-impact-of-channels-timings.html
given these facts, I think 1600 is the optimum, not 1333
Just like changing the multiplier higher for BE chips is overclocking it. Point still stands is that you're overclocking the CPU, since the NB is on the CPU.
I can't even find 1333 CL7 or 1600 CL8
http://www.newegg.com/Product/Produ...1445&cm_re=G.Skill_ram-_-20-231-445-_-Product
there you go, 1600 CL8 ram kit, 2x4GB
If I had an extra $150, and those came in black/yellow, I'd jump on two of those. Mmm... 16GBhttp://www.newegg.com/Product/Produ...1445&cm_re=G.Skill_ram-_-20-231-445-_-Product
Basically the conclusion was 1333 at CL7 > 1600 at CL8.
expensive? $75 for an 2x4GB kit is actually pretty damed good, average is ~$85...
shit 6 CL 1600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231351 same price
newegg has 62 kits of 1600 @ 8CL - http://www.newegg.com/Product/Produ...0006050 600006127 600006158&IsNodeId=1&name=8
link should work....
I hope you realize that CL8 @ 1600 is less latency than CL7 at 1333.
Hmm, lets see the math:
1600Mhz = 6.25 × 10^-10 seconds * 8 cycles = 5 nanoseconds
1333Mhz = 7.50 × 10^-10 seconds * 7 cycles = 5.25 nanoseconds
guess so!
I disagree. 1600 is the maximum, but you get almost no performance improvement going there:
7-Zip improves by %4
x264 improves by less than %1
GTA IV improves by %2
Average improvement 800 to 1066: %7
Average improvement 1066 to 1333: %3.5
Average improvement 1333 to 1600: %2.3
%7 is noticeable. %3.5 MIGHT be noticeable. But you'll never see the difference in %2.3.
You should actually use 800mhz and 667mhz but it still works out in favor of the 1600mhz ram.
That's not a benchmark on an AMD platform, where speed/bandwidth/performance scaling is significantly different. AMD IMCs can benefit quite a bit from 1600Mhz memory (there is more performance-speed scaling when the speed is above 1333Mhz). A bump in the Northbridge speed also opens up significant amounts of RAM bandwidth.
All AMD motherboards are capable of setting memory at 1600Mhz (x8 multiplier, often undocumented), just the AMD CPU IMCs themselves are only rated for 1333Mhz. The reason for this is IMC limitation; according to this official AMD document, you would require an NB speed of 2400Mhz (above default 2000Mhz spec and requiring more than 1.15V) to not bottleneck 1600Mhz. NB speed must be 3 times the speed of the RAM (before DDR). 667 [1333 DDR] x 3 = 2000. 800 [1600 DDR] x 3 = 2400. However, if you overclock the NB to 2400Mhz and run 1600Mhz memory, you will see the performance benefit; otherwise you won't, so AMD did not bother rating the IMC at above DDR3-1333. If the IMC/NB were capable of being within spec to run 1600Mhz, then 1600Mhz would run with no problem across all of the AMD IMC revisions (C2, C3 and E0) and provide adequate performance benefit. And in most cases, the NB can be overclocked/overvolted to meet that minimum 2400Mhz spec.
As for the IMCs themeslves, on the Phenom II x6 (especially the 1090T) they are very robust. The Phenom II x6 can handle 2000Mhz RAM no problem.
I represent the Overclock.net AMD forums where I am among the reputable and respected by members for my knowledge. Does that answer your question?
