Terry Makedon the maker of catalyst said no. I didn't listen, ran it, and totally ********* my windows 7 install. Had to re-install windows.
I have used CCC and Driver Sweeper and the ATI uninstall utility since day one with Windows 7 without any problems. It's the only way to truly do a clean uninstall and clean install.
Again not a single problem with Windows 7 or my HD4770s.
NO. Windows vista+ (meaning vista and 7) Use the new WDDM 1.1 it "unloads" the windows driver (your screen goes black) then it loads the new driver and you don't even have to restart when you upgrade your drivers. I've yet to restart my PC after upgrading my drivers in the past 14 months i've been using vista/7
wrong...with Vista the computer still requires a restart...it's only with Windows 7 where it does not
Wrong.
WDDM 1.0 brought with it the ability to not have to reboot to change out your video driver. AMD released a driver pack (cat 7.9 or 7.10 or so I think) that brought that ability to Radeons. I haven't had to reboot a system due to video card drivers since then.
Nvidia on the other hand always required reboots in Vista. Thus why I didn't bother updating my laptops driver very much. I haven't bothered updating them in Windows 7 either because the newest ones are unstable and crash the desktop on my laptop.
But back on topic:
No I don't use driver cleaner. Haven't used it since the move to Vista. I just install over top per AMD's instructions. Haven't had a problem ever.
