MacLeod
- Jul 28, 2009
Been thinking lately about upgrading to a beefier motherboard, but not really sure I need to.
I built this rig not expecting to get hooked on PC gaming again and definitely didnt expect to get hooked on overclocking and being a [H]ardware junkie! So I looked for a board that was reviewed well, had good BIOS options and was considered well built and had decent upgrade room just in case so I decided on this ASRock 780G board and it has been flawless since the day I first fired it up. It has solid capacitors and seems sturdy and never given me any stability issues. The BIOS has a lot of options to play with and everything seems to keep pretty cool. It even unlocked my Athlon II X3 435 but the 4th core wasnt stable.
One concern is durability. I mean, can a $80 motherboard really be that stout? I like to throw a fairly decent overclock on my gear and this board does seem to handle it well. Without really fiddling with the BIOS settings, Im able to get within 100 MHz of the clocks Im reading about in tests by overclocking experts, so it must be a pretty stable board right? So bottom line is this thing seems stable and sturdy but since I plan to eventually throw on a Phenom II 955 and crank it up a bit as well as something in the GTX460-5850 range and twist on it some too, would that be something I should be looking at a higher end board for? (this one supports up to 125 watt prosc - no 140 watt support).
Second concern is performance. I never though a chipset would matter in gaming if Im running a discrete GPU but am I robbing myself of framerates by using this dated 780G chipset instead of a 890FX? Cant find too many old vs new chipset benchmarks online.
Im looking at 890FX boards, primarily the MSI and Asus. The Crosshair IV gives me wood and I really want it but do I NEED it? Im on a very tight budget and could put that $210 towards other things especially with a wife looking over my shoulder but I dont want to invest in a great CPU and video card and have a motherboard that cant hack it. Or is a motherboard a motherboard and as long as it has quality core parts, is the only difference between a $80 board and a $200 board the play pretties and tinkering tools?
